K
KAS1
Why does everyone seem to use the earth bar in a CU as the MET, what's happened to the old 4way or 8way earthing terminals, are they now a thing of the past in domestic installations, it doesn't seem right to take the water/gas bonding conductors etc to the CU IMO
It also makes testing and inspection a much easier exercise to have an external MET block!! Sod all that messing around inside a tight CU, to disconnect a main earth or bonding cables just to test then having to try and reconnect them again!! lol!! MET block everytime for me, for a domestic CU...
I almost always fit an external MET on domestic jobs, for the above reasons. A couple of inspections ago the Elecsa chap thought it was a bit unusual and couldn't understand why I was doing it 'cos there was a perfectly good earth bar in the CU!!
Just shows how inexperienced these so called inspectors are " Elecsa chap thought it was a bit unusual and couldn't understand why I was doing it 'cos there was a perfectly good earth bar in the CU!! " As far as I'm concerned the CU earthing bar is for the individual circuit cpc s lol
It's totally acceptable to use the CU earth bar as the MET, however I have never done it (not even once). External MET every time. Seems some folk nowadays are trying to strip every conceivable expense out of a job to offer it as cheap as possible.
'Cos it IS better, and LOOKS better. So there.
or there is this.
If your talking about Domestic Installations then the answers are (1) cost and (2) convenience (3) 7 day part p training. anything else hehe.
I don't see the big deal. In a domestic situation the earth bar of the CU can act as the MET as it is usually provided with a couple of bonding terminals as well as an earth. If you struggle to get a 16mm earth and several bonds into an earth bar THEN it would be appropriate to install a separate MET. Neither option is right or wrong - it depends on the application.
