P
padmore12345
Hi guys
been working on new builds for the last ten years so havent had much experience with tt supplies for a while and need some advice on a tt job ive been asked to have a look at.
the situation is this, gone to a mates house whos had his consumer unit changed by girlfriends uncle or someone and noticed its a tt supply. the unit is an mk 16th edition board ie 100a main switch, breaker, breaker, breaker, RCD, breaker, breaker, breaker etc. pretty sure from college memories that the whole install has to be cover by an RCD before the consumer unit, which it isnt. ie its suppliers cut out fuse, tails, meter, tails, consumer unit.
was after advice from you guys what do you thinks the best option to get over this
1) stick a 17th edition dual rcd board in, will this cover the all circuits with rcd protection matter and discrimination???
2) get another Rcd and split load kit to cover front half of board ie main switch, new rcd, breaker, breaker, rcd, breaker breaker etc
3) get new rcd and enclosure to front the whole install between meter and ccu, cut meter seals etc(not to keen on this)
4) or your suggestion
also ive seen the rod has been installed under the floor in the hallway a couple of metres away from ccu in understairs cupboard, is this okay or should it be accessable outside somewhere in an inspection pit or will this suffice as long as the loop readings are in acceptable range.
cheers in advance for any replies.
