P
pushrod
What would you do if you were called to a house where the above has happened?
Would you chop the affected bit of cable out and crimp in a new bit of cable, tape them up (or protect with a bit of channeling?) and plaster over the top or would you have to take out a whole section between sockets, JBs, switches etc. Or something else? Do people generally make good plaster work themselves or just do a rough job and tell householder they will have to take care of the final finish?
Is anything needed in this case certification-wise?
Just trying to imagine common scenarios for the future and if a bit of plastering is another skill i need.
cheers.
cheers.
would you need an electric hot air gun for these or would careful use with a gas burning hot air gun do
