E
Eckaslike
Have just completed an extension & fixed a new 10W dual RCCD Consumer unit for new circuits & existing. Started testing & discovered that although the test buttons on both RCCD work they wont trip when carrying out a RCCD test. I tested the external Ze & obtained a reading of 750 ohms, underground service with an earth clamp fitted.
I checked the earth clamp on the incoming cable which is the old type with lead sheath with steel protection and the connection is good. So should I install an Earth rod
connected to the earthblock & write this on the Electrical Certificate. Any advise would be apprecated, thanks.
