B
BestGear
Hi Guys
I was using a neon screwdriver in friends house, to confirm the power had been removed at a ceiling lighting junction box.
The junction box was to be replaced - a straight swap as something in the attic had fallen on it and cracked the casing.
I brought in the feed live, neutral and earth first, noticed that if I touched earth or neutral with the neon screwdriver, the neon lit up!
Obviously I was not expecting that... so assume the earth impedance is kind of high, and as for the neutral - gob smacked that it was not at earth potential..or very close to...
I made good the repair and left him to get it checked by a pro...
What do you think?
Is this common?
I did not use a meter to measure impedance or even floating voltage on the earth or neutral, which I could have, but when it was enough to light a neon (which is min 90v from memory) I walked away...
I appreciate that the current to light the neon is tiny, but surely that ain't right!?!?!?!
David
What do you think?
Is this common?
David
