• Thread starter Chrislittle
  • Start date
  • Replies 48
  • Views 4K
Currently reading:
is this allowable
Discuss is this allowable in the Electricians' Talk area at ElectriciansForums.net
C
Chrislittle
Quick question, I don't really do house rewires but a friend asked Is it possible to run a 2.5mm ring feeding several fcu. These would then feed several double sockets. the ring would be connected into the supply side of fcu and only the 13a double socket would be in the load.
So example x5 fcu each one feeding its own double socket
I didn't see a problem but I could be completly wrong as I don't generally do that work
I'm too confused to even take a stab at ths one so I'll leave it for someone more local to you who might understand your layout better.
Are you a qualified electrician or is this a DIY job?
Just finish of my training just test and inspection to do. The last job similar to this was I run a radial about 5 fcu each one feeding one of those ceiling ac units.
The job is a mate's kitchen diy jobby he just asked me a question been bugging me as keep you ting myself
Nothing electrically wrong with the set up, just totally bizarre as to why anyone (certainly an electrician) would use such a wiring system. Basically defeats the point of installing a ring circuit!!
You could be right, at first I assumed it might be some bizarre UK standard installation I hadn't heard of.
Im confused too, I think ! Or am I ?
Do you/your friend mean as in a kitchen where many kitchen fitters put a fcu in the ring, above the kitchen worktop which then feeds a socket outlet for a freezer, washing machine etc ? In effect a spur from the rfc for each appliance ?
Basically he wants to run a rfc in kitchen for his appliances but use fcu's supplying double sockets. Instead of pulling appliances out to get to sockets he wants to fit fcu above worktop then run cable in wall to double sockets. If that makes more sense
I assume he's got 2 or 3 undercounter appliances so why not just run each one on its own radial and it's own MCB in the CU. He'll be able to isolate them individually that way without having a wall full of FCU's.
Reply to is this allowable in the Electricians' Talk area at ElectriciansForums.net
