S
Silly Sausage
Some people would be happy with a £9.99 string of xmas lights.
A chip pan fire is an awesome way of decorating your kitchen!
It doesn't sound like it's against the regs or unsafe just somewhat strange...So from what I can work out from reasonable response is its ok but not the best design?
Me thinks we're not being told 100% of the story, as I so often the case.It doesn't sound like it's against the regs or unsafe just somewhat strange...
Quick question, I don't really do house rewires but a friend asked Is it possible to run a 2.5mm ring feeding several fcu. These would then feed several double sockets. the ring would be connected into the supply side of fcu and only the 13a double socket would be in the load.
So example x5 fcu each one feeding its own double socket
I didn't see a problem but I could be completly wrong as I don't generally do that work
