Discuss Micc conversion from imperial to metric in the UK Electrical Forum area at ElectriciansForums.net
We have found we can`t match metric with imperial.....so have used the nearest imperial gland to terminated in adaptable box, crimped and continued in metric....is there a better solution...??
What particular size do you need to terminate?
certain metric glands will fit imperial micc a digital vernier is what you need, the pots can be a problem to fit correctly but as a last resort you could drill the pot thread out and solder them on
Or look for the 3-digit number on an existing gland to confirm the replacement gland size. If you know that and the number of cores it completely identifies the original cable. E.g. a 2-core cable in a 234 gland would be 0.0015 sq ins or 1mm²
8mm OD on a lighting circuit? 8mm is 0.315in., for a 440V 2-core that would be closest to 0.0045 sq ins which is about 2.9mm², which is 0.324in OD. For a 660V it would be closest to 0.002 or 1.3mm² which is 0.340in OD, but would not expect a 660V cable on a lighting cct.
Check that number...
Reply to Micc conversion from imperial to metric in the UK Electrical Forum area at ElectriciansForums.net
I've just been fettling some 50 year old 2L2.5 pyro (MICC) to relocate a plug socket. I probably bent the cable a little more than I should have...
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
Hello, I am looking for an electrician who has an expertise in dealing with MICC (mineral-insulated copper-clad) cables. It is a domestic job in...
6K
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi. We live in an older house and we are doing a loft conversion. We do not have an SPD on the connection to the grid and the builder's...
5K
