I
iamelectric
will charging my drill batteries from a 12v inverter in my van drain the van battery , anyone know or do this and have any problems
Have a 500W inverter hard wired into the back of an estate, i use it for charging and my grinder. I have a large battery because its a 3 litre diesel, no issues with draining the battery as in a typical day i cannot use and recharge my batteries that much so it gets charged up on way home. Pretty sure mines the cheaper pseudo sinewave rather than the pure sine wave which some devices prefer. The pure sine wave inverters cost more cos they have to filter the output to make it nice and smooth
Caution! Some tool chargers require a sinewave supply. Using them on a 'modified sinewave' inverter can damage the charger. 'Modified sinewave' actually looks nothing like a sinewave, it is a tri-level step waveform designed to have the same form factor as a sine, but is not compatible with phase-angle controls and some direct-off-line chargers.
Modified sinewave is one of those terms I hate with a passion. It was obviously made up by some half rate salesman who knew nothing abut inverters or sine waves whatsoever. It suggests to the uninitiated that there was once a sinewave and it's been 'modified' as in slightly altered. AsLucien says, it's a downright lie and misrepresentation, what you actually have is a square wave with the corners slightly cut off in steps.
Modified sinewave inverters play havoc with anything electronic, there's a good chance your battery charger won't work on one and it may even get damaged. Avoid them like the plague.
we've had a few vehicles fitted with Antares 1600w modified sinewave inverters and they've worked perfectly, running all manner of electronic equipment, including all manner of chargers
the only thing that won't run properly is anything containing an AC motor
Antares, Victron, Sterling, Xantrex and Mastervolt are some quality manufacturers
too many factors to include. charger power consumption, battery capacity, how good is vehicle charging system.
best not use one when engine is stopped as it will drain the battery pretty fast.
with average charger taking 100 watts of power vehicle charging system should not have a problem with that.
get yourself one of those voltmeter gadgets pluggable into lighter socket and watch it over a period of days.
you can use charger with modified sine wave, usually no problems with that. good to invest in pure sine wave for some sensitive equipment, testing gear etc.
Got mine from Halfrods, think its a Ring, so far have used it for :
Hitachi battery charger, Makita Battery charger, 4 inch angle grinder, temp flourescent lighting, Robin PAT tester, Samsung phone charger, HP laptop charger.
Thinking of upgrading so that i can use my heatgun.
I would be wary of running a PAT tester from an inverter, especially if you are using tests that energise the equipment under test e.g. leakage current and possibly earth continuity because that's transformer-fed. The test calibration may be incorrect with any waveform other than a reasonably undistorted sine. A 'modified sinewave' inverter could cause the energised equipment to deliver a significantly different leakage current due to the higher dV/dT in the step waveform.
TBH, was a little nervous with the PAT tester but was having to do site tools in a car park to avoid induction. Its a really old type one. However the readings were as expected as was doing extension leads and the like.
Wouldn't recommend anything expensive being plugged in regardless of inverter type.
