Discuss 12v transformer in the UK Electrical Forum area at ElectriciansForums.net
buff69
Hi vent-axia Svara bathroom fan going in zone 1, vent-axia PSU centra selv lo-carbon (12v transforme) question = how far can the PSU be from the fan, i would like it about 1.5 meters from the fan (cable length) or must it be as close as possible (in the loft) to the fan 1.5mm twin+earth cable any help much appreciated thanks
The tech. data for the fan says the motor is 4 watts, so thats about 0.3 amp at 12 volts, say 0.5 amp max.
So there won't be any significant voltage drop over a couple of metres of your 1.5mm cable. ?
in fact only 12 millivolts, so you could use a less substantial cable if needed!
Thanks Avo Mk8 that’s excellent so plan A back on the table lol I want it above the bathroom door on the outside so I don’t have to mess about in my loft ( big spiders lol ) many thanks ?? ?
Hi what cable could I use instead of the 1.5 T&E cable please many thanks
If you were doing the fixed wiring of the house electrical installation I would say 1mm T&E.
But if you are just talking about the SELV side of the power supply to the fan, I think you could use say 0.75mm white mains flex.
Hi yes should have said it’s the SELV side so 0.75mm white mains flex sounds good. The fan will be around 2 meters cable length from the 12v SELV.
Reply to 12v transformer in the UK Electrical Forum area at ElectriciansForums.net
details 12v outdoor fairy lights 20m in length, coaxial socket UK 240v plug that with built in 12v 1amp transformer 220v-plug/12v-transformer...
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
Hi Everyone, I'm New to this forum and am hoping to obtain some advise if possible please? I have a situation where a megaflow system is...
5K
Sorry for the long first post, I wanted to be as thorough as possible. On my landing I have a 2-way switch setup, one of which is 3-gang, one of...
Hi all Went a job this morning to check out vent axia Gemini twin fan...the ducting type that sits in loft and takes air from loft and vents it...
