M
m1ck_b87
Hi all
I'm struggling to get my head round while I'm getting 15v on the ring main cpc, but when I turn the lighting circuit off it drops to 0v can any1 else work this out.
what tester are you using? Multi-meter by any chance? I expect there are downlighters on the circuit and as all the CPCs are joined together via the earth bar in the board your getting a reading from somewhere. Have you tested the circuit out to confirm either way there isn't a short somewhere?
Using a fluke multifunction testing and I've got the ring legs disconnected from the earthing terminal
your getting induced voltage from somewhere , turn off 1 light at a time and keep checking the voltage with the ring circuit fully disconnected , try and pin it down to a particular lighting point then
i agree with induced voltage. cables running together for a few yards will give this. try measuring with an avo analogue meter,bet the voltage fades into the mist.
