Discuss 16mm Swa glanding Help.. in the Australia area at ElectriciansForums.net
W
Welshsparky
Hey
Ive got a job later in the week , running a 16mm 4 core Armoured along an outside wall and making off into a suitable outdoor box. Can anyone suggest the best type of box to use? Had a quick look at the wholesalers today but they didnt really have anything that suited, Im just looking for something ip65 rated which i can easily gland the armoured into ( with room for the Banjo!)
Many thanks
Tom
Hey
Many thanks
Tom
take care with how you lock the banjo mate as you must sandwich the banjo between two hex locknuts (u may well be aware of this if so tell me to shut up ) we use the newlec style eath locking nuts they are expesive but great to work with
Buy Newlec Cable Gland Earthing Nut Set, 20mm - NLENS20
se
surprised anyone uses banjos any more. these earth nuts ( pirhana and SWA do them as well as neweys) are the dog's nuts for glanding.
paid about the same las tim ei bought some.
[QUOTEtake care with how you lock the banjo mate as you must sandwich the banjo between two hex locknuts (u may well be aware of this if so tell me to shut up ) we use the newlec style eath locking nuts they are expesive but great to work with ][/QUOTE]
Must say I have never heard of that sanwiching banjo between locknuts where did you get that info, always learning in this game
do you need to banjo it? are you using swa as cpc? will swa be earthed from other end? do you need continuity of SWA?
do you need a banjo? well if your relying on armour for the earth i would say yes you need the banjo, it will have been tested to make sure it will take the fault current ,but will the locknut currenthave been tested to take the fault ?
Must say I have never heard of that sanwiching banjo between locknuts where did you get that info, always learning in this game[/QUOTE]
It recommends this in GN8. As with expansion then contractionin heat/ cold with the plastic the effectivness of the earthing may be reduced. but by sandwiching the banjo the good continuity is always achived
Reply to 16mm Swa glanding Help.. in the Australia area at ElectriciansForums.net
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
4K
I'm running SWA up the outside of a house and am wondering how best to make it off. It's going to come from the loft area, to the outside, down...
Hi all I'm installing an Garage consumer unit in an outbuilding being converted to a studio for a photographer just 1 ring main and lighting...
4K
Hello, I am renovating a house. I am rewiring myself. I am getting an electrician to install a new consumer unit & test all my work. I'm looking...
Long time lurker so this may be my first question. I am a qualified electrical engineer, but in aeronautics not domestic installations, and I may...
9K
