If that old cable in connector blocks behind the surface sockets is proved as RFC......
extend both legs with blocks or crimps to bring the surface socket into the ring. Then spur off as usual for your extra socket outlet.
When i was in the industrial sector all our ring circuits (mainly in office areas) were all 7/036 but i'd say 99.5+% of domestic rings of that era, would have been wired in 7/029. Extremely rare to see a domestic ring wired in 7/036!! Damned sight better cable than the solid metric rubbish you're saddled with today, unless you special order stranded metric cable!!
Thanks to you all for prompt and helpful responses. I'm glad I asked, the 'history lessons' are interesting too! I haven't measured the cable but am guessing it's .036 rather than .029 because I cannot fit two of them into one socket terminal. It does seem to be a ring, though, so I am going to use the existing junction to break and then extend the ring rather than add a spur. Thanks again,
