Discuss 2 switches into 1 in the UK Electrical Forum area at ElectriciansForums.net
I have 2 single light switches I want to put into a double switch.
At present there is
  • a one way one gang switch
  • a two way one gang switch
I want in the double switch
the same
Please see the pictures for more details.
Im from the UK but this setup is in france so a bit confused and all the workmen are off til at least April 15.
thanks very much
Either buy parts to make from grid switch systems or buy a 2 gang (single plate wide with 2 switches independent of each other) 2 way switch and wire 1 side as 1 way control and the other as 2 way control....
..or am I missing something?
Normally in France the existing switches will be momentary i.e. don't switch down and stay down, but spring back to the original position, if so they are on a latching relay in the DB protected by an MCB, it looks like you have three circuits there and one switched live wire not connected?
Normally for connections between switches.
[automerge]1585565649[/automerge]
Sorry did not give all the information, Convention is Orange is switched live which goes directly to the lamp holder from the last switch and Purple/Violet is between switches, the wiring on the pic's looks a bit odd. ;)
[automerge]1585566443[/automerge]
This may help the OP:
Reply to 2 switches into 1 in the UK Electrical Forum area at ElectriciansForums.net
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
