Search the forum,
Discuss 20mm pvc box with side knockouts. in the UK Electrical Forum area at ElectriciansForums.net
decent step drill bit, and make sure the boxes you buy have a decent thickness to them and not thin brittle ones. then use the step bit to create the holes. a careful positioning will alleviate most problems. if you can use a t square and make pilot holes to keep them in uniform position
Hi - something like these?
PVC Box - https://www.toolstation.com/pvc-box/p53404
Reply to 20mm pvc box with side knockouts. in the UK Electrical Forum area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Hello, Im really new to the world of conduit. I have some 25mm pvc conduit and cant for the life of me seem to fit back boxes with 25mm...
6K
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
Have an isolator switch with 20mm screwed entries into the bottom. Have existing 25mm conduit I want to run into it. Ideally I need a simple...
Hi Guys Any one know the current carrying capacity of a 4mm 3 core single phase sy cable ran in a 20mm pvc conduit? Not sure of the right table...
