P
petewan
been ask to do a job big hob 10.4 kw, 3 3.6kw ovens
i'm thinking 10mm cable for hob 40amp mcb.
2.5mm radial feed to each oven 20amp mcb.
any other ideas
thanks pete
More info about the installation would help. But 6mm and a 32amp MCB will be fine for the hob (using diversity) if it's a standard domestic installation.
thanks llywelyn, the hob is only 5m away from the c/u just thought big is best and ive got a bit of 10 mm just right for the job
I would say if someone was looking at having 3 ovens then there is a high chance all the rings on hob will be used as well, so i would stick to your 10mm for the hob mate. I would look at using 4mm for ovens also as all that loading at the same time will enduce a bit of volt drop in the building. I guess the cables will be running together so will be running warm also.
The pepperoni feast is in the other oven
thanks all for your input, its a large kitchen extesion , it has 4 ovens in all one works off a 13amp plug steamer oven
This all sounds like just pure stupidity to me, who would ever need 4 ovens in a domestic Kitchen for god's sake?? Some medium sized restaurants don't have or need 4 ovens. This smacks of snobbery to me and the need to impress... lol!! Let's hope they can actually Cook!!! lol!!!
I think your right E54, I did a kitchen fit job in Epping. Kitchen cost £45k, It included 2 double ovens and two hobs, I said to owner you must do a lot of cooking ! and he told me the wife don't know how to cook. The kitchen was designed for them by a private designer and the owner could not make there mind up on which cooking setup to have so they had both.......!
Forgot to say, yes they had three 4x4's on the drive.
