You sat this site is TT so is there not already rcd fault protection in place. Why use an 80A fuse at the main board to feed another board when you could just fit the correct size of fuse at the main board.
Can't change them fuses at the moment, they have asbestos behind them, the whole board is going to be changed sometime this year ( NO not me ) it is quite old, and I doubt you will be able to buy any for that box now , yes there is a 3 phase 80A RCD with delay feeding the house and the farm, it is easier for me or a Electrcian just to put another unit from that fuse and it will give me a couple of more MCB's to fit at a later date if needed ! ( each phase has its own meter )
We had trouble awhile back with the main 3 Phase RCD tripping , then it was very difficult to locate the fault, now the House is on its own RCD and the Farm is split with a further 2 RCD's , the 8 way fuse box near the main fuse box is full, so it makes sence to have some spare ways to use at a later date !.
Spike
After reading this I am 100% certain you are not competent enough to do this job. Its time to call in a competent electrician. You haven't got a clue about any of the equipment your talking about, your asking incredibly basic questions, the terminology your using doesn't make any sense and personally i think your taking a massive risk doing this work yourself. Someone will be inside this, don't undermine their safety to save yourself a few quid.
