T
timo1
Hi all. I'm after opinions on a proposed modification to a circuit. Would it in theory be permit table to spur from an existing socket point on a ring final in 4mm to service three sockets, in order to remove the need for an fcu? (as it will be a spur of a spur)
My reasoning is that the 4mm is adequately rated to the 32a mcb of the circuit which would remove the need for an fcu? I have tried to extend the ring but I cannot access the cable sat the correct socket so I have to use the only point available to me. There is no space for an fcu where I intend to run the new points (t.v and sky box)
I could also de-rate the circuit and split into two radials but it would be nice to keep the 32amcb. Although not standard, I can't see why it be unsafe ?
Ps...few spelling errors caused by auto fill on my iPad
