Ok, I'll give you a hint. You would be correct if you were after the line current. Try the calculation again but start with working out the kVA rating of the load first.
Edit: Another tip, you're waaay over thinking it!
For a DC motor starting with no series resistor it would need a supply of 42KW to get it going. The motor will fail if the wiring didn't. I know it's not the question you asked, but I don't do peoples homework! Even when asked in a plausible 2nd party manor :p
Where is this lovely manor? Is it owned by the National Trust?
