G
gerry.slater65@
Hello all,
Just a quick one; what does the term " high integrity" actually mean in regards to a CU?
What is the the difference between one which is high integrity and one that is not?
Thanks in advance,
Gerry.
Difference seems to be around £20-30! ;)
From experience - but not necessarily the defiintive answer - I'd say it was flexibility of bus bars.
Put in a Wylex NH box - dual RCD etc - but couldn't put in a RCBO just to supply smoke/heat detectors. Wylex support line said the NH HI version allowed this as you have a spare neutral bus bar. This was a NHRS10SSLHI, by the way.
As I say, not sure if that's the full answer - I'm interested to know too!
High Integrity can be configured a number of ways. They have 3 neutral bars so you have 2 for the RCD's and 1 for MCB's/RCBO's off the main switch. I think thats about the only difference :)
Hi iron tripped socket switch and is now flashing yellow instead of red have tested all sockets with tester and .
are all fine and working but still continue to flash after I reset it.
Ray
Ray
Hello @Billybluelite this thread is ten years old and won't really get viewed. Try starting a new thread.
