Hi everyone, I need a advice , I’m looking to buy a vending machine, manufactor said the consumption is 3.5kw, peak 5kw for few seconds. They installed a 16amp comando socket. I know when its reached 5kw will need more then 16 amp, or I am wrong? I know the wattage divided by voltage resulting Amp. I request them to install a 32 amp comando socket , machine will run 24 hours. I was wrong? Thank you in advance.
