V
VoltzElectrical
so flex is good enough for a plug top with all the abuse it gets, but no good for a socket outlet which just sits there?
That's about the strength of it, flexible cables were designed for appliance/plug top use, they weren't designed for fixed wiring with varying loads that could be in place for 20, 30, 40 years or more!!
When all said and done, flexibles shouldn't be used as such in any circumstances, without crimped cable end terminations....
Sounds like even a plug top needs to be wired by an electrician with the correct (ferrule) crimp tool. That'll go down well with the man in the street.
Not disagreeing with that, by the way, given the number of badly wired plugs I've seen.
