Discuss Any one else agree in the UK Electrical Forum area at ElectriciansForums.net
Distinct lack of green sleeving.
Why sleeve some and not all?
Are you working on this? Add an extra to your price to bring that into the 21st century
What do guys normally use to extend cables when required??
Wouldn't it make for a better and tidier looking job to pull legs out of board and use a mf fitting and new legs into boards rather than crimps that look absolutely crap
if it's just a few need extendin, e.g. the cpc's are too short, i use ideal in line connectors in CU. if it;s a lot, then an adaptable din rail box, as in one i made earlier (see the blue peter connection). the cpc of the 6.0mm was re=routed after the photo.
I love doing these sort of domestics , they are right in my wheel house as a house badger.
Usually an IP box or Adaptable box like Tel is a very neat solution to multiple extensions to a new position.
If not I will fit the biggest board possible and use in line push connectors to lengthen cables and try to hid the joins behind the mcbs
Either way if I saw the consumers unit in the OP , I would be ripping the whole lot out and starting again...
Reply to Any one else agree in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
Quick question. I want to put an isolating 2p switch on my incoming supply from the meter to the board. I want this to allow easier board changes...
Hi I am trying to replace my old white light switches for nice chrome ones but the wires are all red but the new switch has only l1 l2 top and...
I’ve been asked by a builder I know to rewire a property he’s renovating, I’ve been involved in a few rewires before but never priced one. Just...
Hi, me again :) NICEIC prices per certificate are going up, can you recommend anywhere else to buy them please?
