Discuss Anyone help identify this? in the UK Electrical Forum area at ElectriciansForums.net
timhoward
Supporter
If relevant, the property did once have an overhead supply:
Thanks. Never seen one before!
I think it's just a communications hub for the smart metering... so it does the wide area network communications and the meters just talk to it.
Thank you. I wonder if it has an internal fuse.
I never got as far as looking at the gas meter which would have probably provided the remaining clue, as opening the loft hatch created a waterfall so priorities shifted somewhat! Poor customer originally wanted a new CU and some new sockets. As Sockets have IR of 1.2M, Lighting 0M and house is unoccupied with bare floors and no kitchen it's an obvious rewire opportunity.
Reply to Anyone help identify this? in the UK Electrical Forum area at ElectriciansForums.net
Might be a silly question, but can a tt supply come into a property via underground . This property in question, has no overhead cables...
I am looking for the connector for this rotary position sensor. The sensor is originally normally used for an EZ-GO golf cart as the throttle...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
This is a pic of my electricity meter for my Spanish apartment. I can cycle through the screens using the orange button, however I am trying to...
This electrical item sits on top of the plaster from the roof. There is a humming noise coming from it, it puts out a lot of heat and sometimes...
