Why touch the fuse at all ...........use the VOELCB as your isolator and keep it.
It looks like it doesn't work anyways as the Earthing conductor is coming into the bottom of the unit and there is nothing in the top, the Zs readings in this installation is worth looking at.
As an isolator it would be perfectly serviceable, in fact better as it will be rated for fault make and break. Saves all ethical problems with pulling the fuse.
Nice one Malc.
Would anyone really leave this ancient thing in place and replace everything else? As has been suggested, replace it with a modern isolator, no need to pull the main fuse if you're careful, unless it really isn't sealed.
Would anyone really leave this ancient thing in place and replace everything else? As has been suggested, replace it with a modern isolator, no need to pull the main fuse if you're careful.
Don't you have the HSE over there S in Guernsey and live working?
You leave it if it's serviceable as an isolator for the reason Tony pointed out, it saves you breaking the law if you pull the fuse, it saves you time waiting for the DNO, it saves the customer money.....there are a few reasons as often boards are tucked away in cupboards and not in sight
Yes we do have H&S, but its a matter of being practical. As this installation is so straightforward and accessible (not jammed in a cupboard under the stairs) it would be an easy live swap.
LEAVE THE DAMN THING ALONE!!.....its not detremental to the install.....in fact, as malcolm has quite rightly pointed out.....what you have here is a fully servicable DP iso in circuit......
sometimes i wonder at those that just think `oh, that looks like its gettin on a bit.....gotta go has that`....before accertaining wether its good for continued service..or not (in one capacity or another)....:D
cutting the seal and pulling the fuse is NOT illegal so lets get that urban myth out of the way right now - prosecutions are only brought about if electricity is extracted without being paid for , end of.
so stop mincing about and ditch the prehistoric veolcb for a 2 pole switch and take it from there.
and if it`s manually making n breaking ok?....
Used solely as a DP main switch, i can't see any problem what-so-ever, it's also probably better made too, than today's equivalent offerings of DP switches!! lol!! With the added advantage of being totally free and in place!! Just disconnect all earth conductors from the unit and connect into a MET earth block.
If this installation is going to remain on a TT system it would be a good idea to replace the CU main switch with a 100mA S type RCD, to give the installation additional protection....
To me, leaving the VOELCB is like demolishing an old house and building a new one, but leaving and re-using the crappy old wooden porch stuck to the front, instead of renewing everything at once.
exactly , its pretty laughable to replace all the other mains wiring but leave that in.
change it anyway - it looks crap and at 40 years old has come to the end of its working life.
and how do you know it has eh?...tested it have you?....
the point i`m makin `ere is you dont just start yankin stuff out....regardless of age (within reason of course)......
is it good for continued service?............
personally i'd class it as part of the dno side, if it works arrange an upgrade of meter/tails and isolator from leccy board, once you have completed.
and by the same token how do you know its in good enough condition to be left in ?
the fact its at least 40 yrs old suggests its come to the end of its usefulness.
