Y
Yooj
And I always thought the plug top law came in to cut down on the number of badly connected and wrongly fused plug tops fitted by joe public
For sure, hence why remove it, leaving the chance for a badly fitted plug-top/poorly wired installation to occur at a later date.
Don't agree that your method is cheaper, accessory costs I have looked at the FCU / FO are cheaper than your arrangement. Not all equipment is required to have plug tops fitted by law therefore adding the cost of a plug top and additional connection time increases the costs of your method. While you may feel it is poor design, without the full details of the installation and design reasoning it is difficult to say
Plug top integral with appliance - no cost to installer
Connection of DP switch - time same as FCU
Connection of socket - less time than flex-out as it is one set of connections instead of two.
Crabtree FCU - £3.06
Crabtree DP Switch - £2.52
MK Flex Out - £3.42
MK 1 Gang switched socket - £1.94
These are without looking very hard - 30% reduction in cost already.
Given the number of plugs and sockets in inaccessible places I have replaced due to overheating / burning over the years I think that hard wiring does have it's advantages and is a design plus. Given the reliability of appliances the gains / losses of each method are negligable and could be argued for a long time
Please explain how the flex-out will help the overheating?
Yooj
nice and tidy
