Spazz
I have been installing several appliances lately in rental properties and the agents/landlords have been asking for installation certificates.
Im not happy to issue a Minor Works cert or a EIC because they all require R1+R2, RCD Times, Zs, Ze, etc.
Has anyone got a plain certificate saying said appliance has been installed to the best of my ability (etc)?
I can create one but it all takes time.
Thanks all
If new, the appliance should have relevant documentation from the manufacturers. If your only connecting the appliance, PAT test. You obviously know what's required if any permanent wiring installation is involved.
They come with all the instruction manuals and operation manuals which get passed onto the owner/tenant of the property.
Some have just asked for a cert to say it has been installed correctly.
PAT does not come into it as the are always new items.
Say for example installing a cooker - the only thing I would do is remove the cooker connection cover off and wire my new cable directly to this and the cooker/hob.
Im not touching the electrical installation at all hence no EIC or Minor Works Cert. If I was to start going down the route of them (which I wouldn't as they are appliances not electrical installations) I would be charging alot more than I am.
Most of these are for landlords because they are to lazy to do it themselves or they dont know how to wire up a cooker/hob etc.
I think its mainly the agent who wants the cert to show it has been installed by a qualified sparky and not Tom, Dick or Harry in the back room with no idea at all.
If there is no physical connection other then just plugging in, i would tell them my invoice is the certificate.
Other than that as above, PAT test.
Thanks Jason - That is what I have been doing but they are not happy with that as they make 15% on top of my invoice so they don't really want to show the landlord the invoice - its a money making game as usual.
I was also going to charge another 10% onto of he whole invoice (the appliance and install) for a certificate so I make a bit more for my time and the fact of a certificate.
Appliance installed in accordance with the manufacturers instructions. But be aware, some instructions state that it must be protected with a RCD!
Cheers.........Howard
Thanks everyone - I have created a basic cert inline with Howard's post.
Just wanted something easy.
I have a recommendation sheet that I submit when I do any work in rental properties and NO RCD comes up most of the time.
I also attach a nice leaflet I have from NAPIT, but same situation all the time - How much - leave it for now.
Hence the other post of mine
