The plants come up often.. One woman used to water her plants above her conservatory sockets.. Then ask why they keep tripping :-)
Hopefully I can sort it out Monday.. Taking a day off it the day.
Hi all,
I am a bit of a newbie on this so go easy :)
I have recently installed new open/reverse gate hydrolic motors on to residential gates in a property of flats. They have been working fine for two months now and using the old control equipment these where just like for like replacements.
The problem which is happening now is sometimes they are sticking closed, not opening and causing the residents to struggle to get there cars in & out.
The photocells seem ok athough ones glass is shattered a bit. (Have you tested them?) When I go to repair or find the fault there seems to be none and I put them back on auto mode to be used through the keyswitches or frequency transmitters.
The factors are now onto me to fix the problem and I can't fathom out what can be wrong.
I know a fair bit about electrical supplys and control equipment as I am a qualified electrician with Hvac controls experience however this seems to be slightly above my knowledge. (Clearly no experience with electro-hydraulic systems. This makes you a down right danger to yourself and more importantly the people who use the gates. These devises can kill!)
Any feedback or help on this would be appreciated.
Glasgow East
Martin
So 6 days, have you contacted the manufacturer? I’ve not read that you have. I would have thought that would have been any sensible persons first port of call, not going on the internet asking a bunch of random guys who really don’t understand the set up.
What have the properties management had to say on the matter? I know what I’d be doing in their shoes and that’s getting someone in that knows what they are doing. You certainly wouldn’t get paid for your troubles, but you would get a bad reputation.
As soon as I read you’re OP alarm bells were ringing in my mind.
For your own sake get someone in that knows what they are doing and I don’t mean your “mate”.
Here pal, it's a very simply set up..
Problem being it was working when I went out..
Changed over the pcb yesterday and as it's a weekend the manufacture is 1st Italian, then secondly closed.. So to is the supplier. Thus why I'm on this forum. Is it not a discussion forum?
