I was recently on a job and fitted the 35mm back boxes and got laughed at by the builder for fitting cooker boxes! It makes it a lot easier fixing the face plates
Builders will laugh at everything we do, usually followed by "My usual electrician doesn't do it that way".
A polish plumber, I had one the other day, called out as lady wanted new heating controller fitting, plumber had been in there! Cheap cash job! No testing-papers. No earth sleeve on anything. Even main earth. Dual board so lights go on the left . Rest goes in on the right! , ring final ends terminated into separate 32amp mcbs.... They said they didn't fit it!
Had a call that weekend as they cracked off the bath waste and raw sewage was now unloading into the walls and kitchen! And toilet was not screwed in and they cracked a new floor tile. Never give these guys tools! Ever
My wife's dad is a spark in Poland, he is very good at his job over there and we have had many discussions (or at least tried to) about various wiring related topics over the last few years. I have mentioned to him about what's going on over here and he is very embarrassed by it to be honest.
the thing is that a lot of these so called polish sparks over here are not sparks at all, just guys that will have a go at anything to earn money, even if they ain't got a clue.
Kingeri...out of interest. Were the 25mm boxes partly chopped into the walls or fixed directly onto the walls before dot n dab boards fitted? I've just recently fitted metal screwless electrical accessories at home with 25mm flush boxes with no problem. Manufacture stated their products suited for 25mm deep boxes.
The only reason I could think of for it being a "have to" is that you can get flat metal faced switches and sockets which require a deeper box. You'll struggle to find anything in either book.
Also if your using' flat plate' sometimes boxes have to be set back an extra 10mm, check instruction on acc's as it can be a pig to sort out once boxes are in and plastering is done. it was probably 5mm
Went to job just today where they have used 25mm boxes in a dot and dab wall, leaving a bout a 10mm gap between the boxes and the wall surface. 35mm boxes would have been a PERFECT fit. Probably another case of the trades not communicating, or else I just blame the turdspreaders.
some acc's need a small gap between box and wall surface, usually flat plate acc's as they have a lip on back of acc which will not go flush with wall unless box is set back about 5 or 10mm, check instructions on acc before final fix on box. thinking back I think it was 5mm, but you should double check anyway ,especially on sw/spurs.
