Hi chaps,
Was painting my bathroom door a couple of days ago and when I was putting it back on, I whacked it against the ceiling light. All three bulbs (230v, 25w G9) instantly got brighter...
I know this can happen with bulbs occasionally due to the filament being knocked and the resistance changing, but can't understand how it can happen to 3 identical bulbs at once! The other odd thing is, they're all still working having been switched off and on dozens of times...
Anyone know what on earth has gone on here?!
That's not the filament being knocked, that's a bad connection in the fitting somewhere. Take it down and check all connections are tight. Daz
Sounds reasonable, but all tested fine when it was installed... It is however one of those fittings which has to be located on it's bracket after the connections have been made, so I could possibly have knocked something.
