C
cardinal
Evening gents.
Currently fitting out an extension with two en-suite bathrooms next to each other. Client has specified two extractor lights, but I was just wondering if anyone had any experience of ducting two fans out the same vent. Ive seen Y-pieces etc on the market, but was a little concerned with the possibility of one fan passing steam/moisture out of the other one, as they are fairly close. Worrying about nothing or potential issue?
Many thanks in advance.
I've considered this in the past but decided that 2 seperate unit would be simpler and for the best in the long run.
s
I agree with you, in some cases separate ones would be better, but tiking each case on it's own merit, it would depend on the situation and use. I thin in domestic cases you're not likely to be using both bathrooms at the same time, every time.
Plus if you're terminating outside on the wall , the fewer grilles the better, for cosmetic reason.
Many Many times, however I agree with murdoch and would avoid doing so if possible and duct seperately, as mentioned you can get a tee with a flap in it to avoid back drafts and smells into other rooms, but this method would be the last I would do unless I had to, and I have had to several times unfortunately, I know building control don't like this method either due to potential fire hazzard and some won't wear it at all.
Valid points and noted.
I wouldn't use fan-lights at all. In my experience they have the sucking capability of an athsmatic ant, as half of the extraction area is blocked with the light, and the lamp-bulbs they come with ("not to be replaced with any other type of bulb") are a silly colour and won't match the rest of the lights in the room.
Sorry to be a negative-ninny, but when the customer of the last extract-light I put in (which she bought herself) saw it she said "that looks sh*t!"
