Excuse my ignorance- I’m just a DIY-er here. When mounting one of these switches on a round wooden patrass do you remove the square back box and plaster around the cables? Or plaster into the corners of the back box around the round wooden block?
Speaking as someone who has installed these kind of switches and patrasses the 'first time around' (just), that's the way they were fitted then, on a flat surface with the cable emerging from the wall, or more often, a surface fixed cable anyway.
I doubt that the modern repros are meant to be fitted like this though. A square wooden patras, slightly bigger than a flush metal box, would be the best way, although if you insist on round, there are plastic round flush boxes available.
That’s brilliant- thanks Brian! Great advice and interesting to hear the way you did them back in the day! Cheers, much appreciated. ??
I once fitted some of these but there was a square wooden back plate that covered the old switch box.
A bracket screwed to the switch box lugs, then the plate to the bracket… finally the switch on the plate. No screws showing.
I think I posted on the forum about it… I’ll have a look
Edit. Found it
