- May 25, 2011
- 6,161
- 7,152
- 10,256,798
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
This follows from a very brief posting last weekend asking if anyone knew where the fuel/water drain plug is on a mk7 T280 - answer suggested by Tel. Anyway, turns out that what I thought was the plug from that thread wasn't, and this afternoon I had a proper look and found it. Drained it, lost a bit of diesel at the same time like you do, put it back and thought all should be well.
Ran for a few moments until it hit the airlock, which I was expecting, then I thought I'd jusy need to crank it over a few times until it drew through. Nah. After a few cranks the damn thing's gone into some bizarre electronic protection mode going 'something's wrong!, something's wrong!' with the master warning light on, and refuses to attempt to do anything at all when you turn the key.
I can see the fuel in the pipe, I can see the air....but even if I drain it through it's still not going to turn over until whatever sensor it is gets reset!
Homestart on their way.............. :driving:
