Stuart27
Trainee
I'm coming towards the end of my level 3 training and in the market for my first MFT.. There's a ton of different brands and each brand has various products so it's all a bit confusing. Can anybody recommend a good "first" tester?
Also is it worth buying second hand? Since money is a bit tight I'm considering buying a previously owned tester.
Any advice on what to look out for when buying second hand would be greatly appreciated too.
Thanks guys.
If buying 2nd hand a calibration cert would be a must for me.
Also would look for RCD Autotest, ability to test type A and S RCD's. 2 lead loop test. Phase rotation if you need it.
buy a megger 1553 2nd hand, calibrated for under £200.
Thanks for your advice telectrix.
I've also been looking at a second hand Fluke 1652, is there any notable difference between the two? All I can see is that the Megger has Bluetooth which the Fluke doesn't.
Seconded. Type A RCDs will now become more commonplace and some older testers do not have that test function.
Make sure you get a fluke 1652C or 1653B
The standard 1652 doesn't do the full range of tests
Been using a Megger 1735 and because I use my left thumb to press the test button, I often find I’m pressing the jog button instead.
Much prefer my Metrel Mi3215BT.
I also like the Metrel, because it can test B type RCDs as well as A and AC types.
Fluke have the test button on the actual leads
It's very handy.
I understand, both Megger and Metrel do a probe which incorporates a test button.
Unfortunately neither my Metrel or the Megger I’m using at work have that type of probe.
