R
ruston
The old Eclipse solid frame hacksaw was brilliant too.
? a 24tpi blade in one frame is a good all rounder.i got a stanley fatmax one for tray and conduit because its heavy and does the work for me.
If im cutting core sleeves and random bits i use that bahco one as its light and easy to use. Ive had mine 3 yrs and havent had a problems so has the other lad i work with and hes is an absolute brute!
talking about bags etc get one with a shoulder strap, you will thank me later (or strap and a bolt to hold it through a stanley toolbox)Not sure if you are in the trainee section yet but I made a toolkit guide that might be useful to you, it is stickied (near the top somewhere!).
That rucksack may be handy for college but likely not so much on site, depends what type of work you will be/are aiming to do.
As for hacksaws they vary far and wide but at the end of the day it is just a frame. You can have the most expensive one out there but with a crap blade you're stuffed! I have a random one, think it's made by Hold-On(?), think it cost me a tenner. I use Eclipse blades which I have found to be very good. As Shanky has pointed out different tpi (teeth per inch) are good for different jobs, I suggest you get one of each and see for yourself!
Go down to "Trainees Only" subforum and should see a thread titled "apply for access" or similar.that guide would be handy.
How do I apply to join the trainee section?
) Though I also have some cheapo silverline/lidl/aldi spanners and they've all lasted well and been fine for fit
