B
bahco
right lads need your help please
ive fitted some lv downlights and a lv fitting in my lounge, took the pendant off into a jb then to the 4 spots and the lv fitting, power on all working fine
then walks past my consumer unit and i can hear a buzzin hummin sound, so i take the lid of listen a bit closer went into the room were i fitted the lights turned them off and the buzzin stops.
now the lv light fitting which i replaced the pendant with had a tranny built in but it was non dimmable, so i replaced it with a osram one
you think it could be the transformer? and also ive replaced the 1g switch with a dimmer, its a 400w dimmer easy enough to take the load but that is makin a slight buzzin sound.
the lighting circuit is on a 6a mcb which powers 4 rooms approx 500 watts which i make round about 3a
getting a bit paranoid now so any help would be great thanks matt
