Discuss buzzing noise in the Australia area at ElectriciansForums.net
F
fire alarm guy
Hi folks. Can anyone please tell me why, when i flick circuit breaker to on for my storage heater timer, I get an annoying buzzing noise. There is nothing loose in the consumer unit.
Sometimes when you get a 'buzzing noise' coming from the breaker, it could be an indication that the breaker may be overloaded slightly.
What breaker is the storage heater on, and what is the power rating??
Ive had it on a lighting circuit(6 amp mcb) -loud vibrating/buzz. Im going to swap it out as i can only see a vibration as a cause of heat in future. The mcb was under hardly any load. Its a new fault to me so cant explain why....
Reply to buzzing noise in the Australia area at ElectriciansForums.net
Hi all I'm after some advice on 2 way CU in a garden office which is 'buzzing' when I turn on or increase the tempreture of the wall mounted...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
Hi - On our small vessel we have a 12v failry powerful motor to run the autopilot, where the power is supplied by the boat's battery bank. On an...
Hi, A baseboard heater in my house emits a short buzzing sound every 30 seconds. It seems to happen only when the room is near the temperature...
I recently buyed a Opel Astra H GTC. It has a CD 70, with Bluetooth and AUX etc. So for music I used used AUX, cause the previous owner left me...
