Discuss cable burn out in the UK Electrical Forum area at ElectriciansForums.net
C
chloebear
I have a site where a large number of circuits were rewired about 4 years ago in LSF twin/earth. these circuits include lighting, showers, sockets etc - all fairly standard stuff on the face of it.
Problems have developed over the last 6 months with cable burn-out on certain accessories - 2x light fittings have burnt out the fittings at the terminals, a shower isolator (50amp) has burnt out & a fan heater has caused fairly serious fire.
Seems too random for poor workmanship - I am now starting to think along the lines of sub standard cable.
anyone out there come across this as an issue & what would be he best way to test for this?????
Did you buy good quality cable from a known supplier or knock off cack off fleabay? If it's the former then I'd say it's unlikely to be that, if the latter it could be cheap counterfeit rubbish from some cowboy out the back of beyond.
Did one person carry out the whole installation?
Any photo's? Is the damage at the terminals of the accessories? Sounds like someone didn't tighten things up properley? Daz
Or maybe they were built like a gorilla and overtightened everything if it's small cable sizes.
Yes I'd be looking for signs of incorrect termination technique. Are the accessories of good make? It's much more likely for a burn-out at a fitting to be caused by the fitting than by the cable. If it were undersize enough to cause burnout you would spot it immediately, if it were not proper solid copper you would feel it as you pull the accessories apart.
Is alot of this issue on fine wire cables?... have the appropriate ferrules been used, not crimping fine wire or using connectors designed for uncrimped fine wire is a key cause of electrical fires.
As for it across the other circuits I'd also pt it down to poor workmanship possible using old rounded off screw drivers or apprentices not getting supervised enough.
Infill following? Over my head mate.
I used to to look after a few building that were wired in a LSF t&e type cable, the cable was about 10 years old and had not handled heat well where it was used with fitting with magnetic ballasts. The insulation would crack badly where it had seen heat within the fittings.
Why do apprentices get the blame for poor terminations and worn screw heads?
I had the misfortune to get teamed with a guy 20years my senior. He was an animal! 12 isolators so that’s 72 terminals, not one had the screw heads intact.
It will only handle heat the same as none LSF T+E.
The magic happens when you set fire to it.
I would like to see Wago connections on sockets/switches
Why?
Bolted terminals have worked perfectly well for decades, if you tighten them properly there should be no issues. OK, the cheap cack has rubbish bolts but as long as you use a decent brand you'll be fine?
I think your idea will be used as an excuse for poor workmanship
Why?
the bolted terminals damage the conductor, besides we could all get home/pub quicker.
Reply to cable burn out in the UK Electrical Forum area at ElectriciansForums.net
I have just been called out to another burning shower switch.Upon removal the wires had been burnt and chared.One thing I've noticed on all burnt...
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
