That's a fair point. In this instance the runs follow the same horizontal line as the wall that does have a more defined zone. So if it's same height above finished floor level, level with the prescribed zones on the other walls, and no more than 150 mm deep, wouldn't that count?
I know you're correct on the point that steel capping won't work in this scenario - the ESC says 3 layers of 1 mm thick steel capping is not same as a single steel plate 3 mm thick - but I don't think that makes sense!
