S
soulman
I need to run 2 swa cable's down a stretch of a building, the building fabric is unsuitable for cleats. I want to run them on tray and cable tie them to it, is there a kit to make the tray stand off the wall or is it just screws & washers.
I also need to make off swa into metal adaptable box outside, i need it to be weatherproof. So i am putting the metal adaptable box inside an adaptable weathproof insulated adaptable box, is there an easier way.
Cheers
Can use bits of unistrut to pack the tray off the wall, or some washers depends on how far it wants to be packed off the wall. If it only needs enough to allow you to cable tie your armoureds on it then some of those large plate washers work well.
As for the adaptable box, whys it gotta be metal? Use a plastic waterproof one and some pirana's to earth the SWA.
He hasn't told us what size swa, plastic boxes get a bit flimsy when you make off anything but the little ones.
Cheers for that, the plastic adaptable boxes i have used recently seem to have got thinner, not much strength. I have found a nice big wiska box in the garage which will do nicely.
Cheers
If you don't know what size SWA so you know what size tray it needs to be and subsequently what size brackets you will need?
