Discuss Cable,pipe,wood finder in the UK Electrical Forum area at ElectriciansForums.net
I find a hammer and nail always finds buried cables or pipes yet never timber when I need one to fix too.
other that no, I brought a Stanley one last year at Elex and found it a complete waste of £30.
i've got a bosch. does the job. never rely on it 100% though. always drill carefully till you're sure you've hit the brick. not like i did at home t'other week. a buried gas pipe looked like a nice wide mortar joint till it started hissing at me.
for looking for wood battens under plasterboards get a small magnet. the stronger the better. slide it around till it sticks to a nail or a screwhead underneath.
...Aye,those buried treasures! some 25 years ago,when replacing my folks back boiler,i found a gas "spur" in the side of the chimney breast,fitted,i imagine,for the old gas-poker feed,which they never had.I left it in,but put a piece of 1/8th plate steel over it and plastered/skirted it in. Last year,after fitting a new Dunsley Yorkshire,the tiler was finishing off,and give it 3 tries with his SDS before giving up...i caught up with him,and said it was a good job i had thought to protect that pipe,and he said "It's not a good idea to do that,as no-one knows what is underneath,whilst if left,we would know a gas pipe ran there,coz it would leak..." :6: a specimen of logic which so far has escaped me...
To find wood it isn't a guarentee, to find a cable or pipe much easier, you can buy pinpointers for metal detector enthusiasts which are brilliant to detect metals in walls and floors, the detectors to find all 3 as mentioned above not worth the money if accuracy is needed to be 100%.
Reply to Cable,pipe,wood finder in the UK Electrical Forum area at ElectriciansForums.net
So was on a call out today and cooker circuit kept tripping the RCD. Disconnected at the board and at the cooker switch and IR’d the cable and...
Afternoon everyone.. During some testing I have found an IR reading of 0.01MΩ between N-E. This is on a length of SWA buried underground from the...
Hi Guys and Girls, First off: I am very new to electrical stuff. Right now I'm running my first ever project containing electrical components. So...
My customer is having a wood burner installed. The stove installers have said he needs to get the 2 sockets that are directly behind the new...
Hi everyone, I need some help with an electrical issue I'm experiencing. I recently created a new circuit for an electric oven at my friend's...
