R
Robo
I'm taking a 16a supply from a house to a remote garage. It's a new build property and the garage is in a block opposite the house. None if the garages have electric.
it isn't possible to take a permanent supply cable to garage. So the customer wants to be able to un real a cable and plug in at house and then into garage when he chooses.
it will have blue 16a commando socket and plug. When the cables in use it will be lad across a Tarmac drive and will have the occasional car drive over it.
What would be the most appropriate cable. Dot really think swa is ideal so was things of braided SY cable or arctic grade flex??
cheers
If it's a new build then do the job properly and install a buried cable. If not then as an electrician don't get involved at all. If the customer wants to run a temporary surface lead later then that's up to them and they must take the consequences. I don't know of any cable that's rated to have vehicles drive over it unless it's contained in a protective steel tube or under steel capping.
I have to agree with this. If they don't want a proper job doing, then you as a professional should walk away.
If they are set on what you describe, point them towards somewhere to buy a suitable length extension and explain to them why this is unsuitable. I also don't see why even when laid on a driveway when in use it has to be driven over.Obviously I haven't seen the place, but i'd have thought it could have been laid around the perimeter to avoid being driven on?!
There is always away , and if the customer will not entertain other ways , I would walk away from it if I were you .
Give it a few years down the line and someone gets a lick from a damaged cable , I will bet my last pound that he will soon be pointing his finger at you and shouting on about how shoddy you were to just leave it like that .
Also from a business point of view you're not going to make much on the installation because there so little work involved and with bread and butter materials like cable the customer can purchase at close to the same price you can so mark-up will be low. From an electrical point of view surface cable across a driveway of roadway with vehicles driving over it is high risk and asking for trouble. Everything about the job says convince them to do it right or just walk away and leave them to it.
cheers
why isn't it possible? Because the customer is unwilling to pay for it?
Thanks for the views.
I fully agree that in the ideal world a buried cable would be the solution. And a catenary wire just isn't practical.
the garages are in a block opposite the housing block. Bizarrely no power was provided. An underground cable isn't practical as it a Tarmac drive with various utilities and the other neighbours won't play ball. Yes, there's not a lot of money in it but it a family friend and I wanna do my best. So a heavy duty cable would be the best option
It sounds like you're talking about the cable being surface across a public access road, not just a private driveway......
If you can't do it correctly then leave it alone, it will be trouble for you later
Robo this a no no it was bad enough for one house but you are talking about something lethal with multiple houses think about kids playing and dogs running round you are leaving yourself wide open to being sued by many homeowners.
