Hi guys
Can anyone recommened a decent cable stripper for flat and 3 core cables?
Here's a couple ove seen online.
www.toolstation.com
And also....
www.screwfix.com
Has anyone had any experience with either of this or any other ?
Thank you.
C.K Automatic Wire Stripper
Save time while working on electrical tasks using the C.K Automatic Wire Stripper. This versatile product is suitable for stripping both flat and round cables and wires. All it takes is two clicks to remove the outer sheath, as well as extracting the inner conductors in a cable.The tool is...
And also....
Stanley FatMax Automatic Wire Stripper 8" (203mm) - Screwfix
Order online at Screwfix.com. Cuts, strips and crimps wires in seconds. Spring-loaded pliers can strip inner and outer sheaths on wires and cables 0.2-6mm. The pliers have crimping capability and are colour coded for crimps on common insulated and non-insulated terminals 1.5-6mm. Bi-material...
Thank you.
