Hi all, I would like to get advice regarding how cables suppose to run underfloor boards: i came across many houses were cables are just laid under floors, the are fitted through joists but they are no clipped. Is it a good practice to leave them like this? or they need to be clipped to the side of the joists?
Thank you for your advice.
Ideally they should clipped . Because of the new fire regulations. But if they are run through joits then they don't need clipping. But along the span yes.
But how clipping cable helps fire regulations?
Fire regulations for wiring cables, primarily from the UK's 18th Edition of the Wiring Regulations (BS 7671), require that cables are supported to prevent premature collapse in a fire to avoid hindering evacuation and firefighting
That's more for surface run cables, Buzz... If the cables are in the void between the ceiling and floor, then they'll be secure as long as the ceiling is.
Obviously, running through a joist give it support for longer.... even if the ceiling board comes down.
If you're going down the route of clipping because of that regulation, then you need to use metal, not plastic clips...... or something like all-round band and a screw
Sometimes, you just cant clip anything if you've fished between 2 downlights for example in the same void.
To clip cables all way through, i have to lift every single floor board in the house, I don't think any of you guys does this, or i am wrong? Please advice.
Just fire clip where you can,each end of the run, it's to help prevent firefighters from getting entangled, I alway imagine how low it would droop with only my fire resisting clips, also I would try to fit more by an exit door compared to next to a solid wall.
Leaving them in void unclipped would not be issue?
Thank you
