F
flex_m
Hi all, just working through an assignment at the moment, got everything done other than two questions worded "select an appropriate minimum sized CPC and confirm your selection by calculation". I've already calculated my tabulated current, volt drop and live conductor size for each question.
Our teacher said we should be using the adiabatic equation, but we haven't been given a Ze, in my mind I won't be able to calculate the PSC because I can't just assume the Ze. It's TN C S, but if I assume the maximum Ze of 0.35 and it is actually lower, the PFC will be higher and my calculation will be incorrect.
Am I missing something obvious here or should I be using a different equation?
