H
High Tower
Can anyone spot the main issue?
can't see any earth to the panel, unless it's via steel containment.
all cables the same color?
Not an issue in a panel, all a.c. power is supposed to be black & has been for many years.
However, the control circuits should be different colours depending on whether they are a.c. or d.c.
Yes it appears that they are fused neutrals, a previous employer I worked for used these as N disconnect links, no fuse, but a solid link capable of carrying the commensurate current.
I can't make out much because its like looking through a pair of binoculars the wrong way round
My guess will be as per sintra, the neutrals look to be fused,they also look like they are not linked
Don't need to be linked, dual incoming supply from different subs.
No DC at all mate
They will (or should be) solid N links as NBP pointed out, hence the carriers being white, they also come in green carriers which designates a removable earth link.
