Discuss Can anyone tell me what make manifold this is? in the Central Heating Systems area at ElectriciansForums.net
rolyberkin
As per the title, looking for a straight replacement for this anyone have any idea of the manufacturer please? Just want to bolt a new one on if possible?
What was wrong with the old one in the end (from your last post) did you find out the heating zones it fed in the end?
Therin lies a story, been there today, the manifold has been attacked by a monkey with a wrench to the point where two zones won’t open, have mapped what zones I could with a flir. I think the issue is that someone has tried to connect a radiator zone and UFH from one programmer. The system is back feeding with the boiler and all pumps on all the time even when no call for heat, previous owner has also decided to connect a cast iron rad across the UFH manifold flow and return. Then they have put the thermostat for the rads in a room with no rads and the UFH thermostat in another room with a radiator in it!?Apart from that all is good!
Reply to Can anyone tell me what make manifold this is? in the Central Heating Systems area at ElectriciansForums.net
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
Replacing 15 year old FAR Italian manifolds (2 downstairs, 1 up) with new Warmup units. However, old actuators have 4 core and new only have 2...
Hi as per title I'm building a sublimation heat press. i have a 1000mm x 250mm x 8mm sheet of cast aluminium. i will be using a thermostatically...
As per title. Does anyone know what this symbol means? It’s on a IP rated outdoor light and there’s nothing in the instructions to say what it...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
