Up grade your rads if there the old cast 1s & fit cieling fans to distribute the heat more ?. Half the cost +
If you have gas heating in the rooms ie fires O/F then perm vents required
The man you got the pics from.diydoctor.org.uk/project_...iling_rose.jpg
I am just going to turn all the power off throughout the house. Who is DRDIY?
Please get a spark to do the work as it could be a nasty shock for you
Right fellas, I have been contacted by one of the members of this forum. He will be visiting my daughters Monday and sounds just the chap I need. Thanks for all the great and knowledgeable advice. You can all breathe a sigh of relief now that I will not be touching the electrics ;-P
Are you looking to install a false ceiling made out of wood and plasterboard, or the kind of suspended ceiling which hangs from a grid like you see in offices?
The latter would be easier to take down in future and would get around a lot of problems such as altering lighting positions.
Wouldnt look good in a house though would it?...
No but the OP didn't mention aesthetics being a factor to consider; I would have thought dropping ceilings by 3' would look odd whatever you make it out of, unless the windows are really low down.
It must have very ceilings to drop 3 foot.
Or he's planning on fixing the new light fittings on a regular basis. :-)
Presumably that should be 'very high' ceilings.
I just got the tape measure out and I could easily lose 3' of my ceilings and it would probably save me a bit on the heating, although it would cut the windows in half and I'd still lose a lot of heat (or gain a lot of draughts) through them.
In my situation I'd replace the windows before thinking about lowering the ceilings.
Just a thought on high ceilings, in the USA in some states where they have hot summers and cold winters, they use ceiling fans, they use them to cool the room in the summer and reverse them in the winter to force hot air back from the ceiling down into the room. Cheaper option than lowering ceilings.
Ben
I agree Brendan, better with a fan or under floor heating as a boost when it's cold. Such a waste to lower a nice high ceiling.
