Alright, alright...very high ceilings!
Easiest and cheapest solution, turn the gas meter around and heating on full blast 24 hours a day.
Just never answer the door.
Are you looking to install a false ceiling made out of wood and plasterboard, or the kind of suspended ceiling which hangs from a grid like you see in offices?
The latter would be easier to take down in future and would get around a lot of problems such as altering lighting positions.
surely the latter would let heat escape quite easily..?
This sounds like the same problem Willy Wonka had when he first decided to provide social-housing for his work-force.With a little thought,a 3-bed semi can be converted into four-storey flats...
The tiles offer good insulation if installed correctly. You can get clips to hold the tiles to the frame, and if all else fails a layer of loft insulation can be laid over the ceiling.
Do the donkey work yourself, (lifting and replacing floor boards etc) and then get an electrician in to extend and make off the connections etc. The cost should then be minimal to you....
Yes, I wimped out and got a chap from the forum to visit Monday. The ceilings will be wood and plasterboard and finished with a skim. I am going to do the donkey work an the sparky the connecting.
Good man, one of the few that come on here asking for advice and actually take it.
good luck with your 'project'
Jacksy, whilst your doing the wood work on these rooms please put a vertical 2' x 4' from the existing rose to the local location of the new ceiling and its rose so the sparky can clip the extended cable to it. 3 foot of T&E dangling in-bertween the two ceilings is not a good idea, it needs supporting.
hope you meant inches there, paul, not feet. LOL. :dots:
