Discuss Can you spot whats missing. in the UK Electrical Forum area at ElectriciansForums.net
oscar21
Took me a while before I realised, the building is a block of 6 flats, all submains go to each flat with the meter and consumer unit located within the flats for each unit.
has someone taped up the original Neutral cable with green/yellow tape?
there seem to be 2 earths from the service head of different sizes, i wonder if one has been mis identified.
No metering to that LL's sub board
Thats the one. Tails straight out of the Bemco (which only has fuses in in) and straight into the LL board via the isolator. There are a few blocks the same as this dotted around, I wonder if they are all done like this. Free electric for years, quite a new board as well, 2018 if the label was from new, why would it not be picked up then.
Ah I see, there are a few things thats rough about it, the service head isn't fastened to anything really, the 6 submains are just held with pinching glands and the new backboard is loose.
Reply to Can you spot whats missing. in the UK Electrical Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Hi everyone, Got a job converting commercial property into 4 flats, 2 up 2 down all with electric meters on the outside on ground floor, SWA to...
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
I live in a flat in Scotland supplied with an old 2 meter system called THTC where one meter using a time signal supplied heating and hot water...
